Nächste Seite - Ergebnis 26 bis 50 von 54
Alt 15.11.2009, 17:52
rolopolo rolopolo ist offline
Vize Admiral
1.542 Danke in 827 Beiträgen
Standard nach 62 Jahren im Schlamm ......
.....lief nach kurzer Zeit der Diesel wieder:
WW II Russian tank with German markings uncovered after 62 years. WW II Buffs will
find this interesting.Even after 62 years (and a little tinkering), they were able to
fire up the diesel engine!
A Komatsu D375A-2 bulldozer pulled the abandoned tank from its tomb under the
boggy bank of a lake near Johvi , Estonia . The Soviet-built T34/76A tank had been resting
at the bottom of the lake for 56 years. According to its specifications, it's a 27-ton
machine with a top speed of 53km/hr.
From February to September 1944, heavy battles were fought in the narrow,
50 km-wide, Narva front in the northeastern part of Estonia . Over 100,000 men
were killed and 300,000 men were wounded there. During battles in the summer of
1944, the tank was captured from the Soviet army and used by the German army.
(This is the reason that there are German markings painted on the tank's exterior.)
On 19th September, 1944, German troops began an organized retreat along the Narva
front. It is suspected that the tank was then purposefully driven into the lake to conceal
it when its captors left the area.
At that time, a local boy walking by the lake, Kurtna Matasjarv, noticed tank tracks
leading into the lake but not coming out anywhere. For two months he saw air bubbles
emerging from the lake. This gave him reason to believe that there must be an armored
vehicle at the lake's bottom. A few years ago, he told the story to the leader of the local
war history club 'Otsing'. Together with other club members, Mr. Igor Shedunov initiated
diving expeditions to the bottom of the lake about a year ago. At the depth of 7 metres
they discovered the tank resting under a 3 metre layer of peat.
Enthusiasts from the club, under Mr Shedunov's leadership, decided to pull the tank out.
In September of 2000 they turned to Mr. Aleksander Borovkovthe, manager of the Narva
open pit company AS Eesti Polevkivi, to rent the company's Komatsu D375A-2 bulldozer.
(Currently used at the pit, the Komatsu dozer was manufactured in 1995, and has
recorded 19,000 operating hours without major repairs.)
The pulling operation began at 09:00 and was concluded at 15:00 , with several
technical breaks. The weight of the tank, combined with the travel incline, made for a
pulling operation that required significant muscle.. The D375A-2 handled the operation
with power and style. The weight of the fully-armed tank was around 30 tons, so
the active force required to retrieve it was similar. A main requirement for the 68-ton
dozer was to have enough weight to prevent slippage while moving up the hill.
After the tank surfaced, it turned out to be a "trophy tank" that had been captured by
the German army in the course of the battle at Sinimaed (Blue Hills) about six weeks
before it was sunk in the lake. Altogether, 116 shells were found on board. Remarkably,
the tank was in good condition, with NO RUST, and alll systems (except the engine) in
working condition. This is a very rare machine, especially considering that it fought
both on the Russian and the German sides. Plans are underway to fully restore the
tank. It will be displayed at a war history museum in the Gorodenko village on the
left bank of the River Narv.
Preparing to pull it out.
Hits:	1210
Größe:	73,6 KB
ID:	170906   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	1020
Größe:	77,9 KB
ID:	170907   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	1047
Größe:	78,2 KB
Hits:	1009
Größe:	79,7 KB
ID:	170909   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	1003
Größe:	75,1 KB
Alt 15.11.2009, 17:54
Vize Admiral
Kennt jemand den Panzertyp, soll ja russisch mit deutschen Markierungen sein ??
Hits:	975
Größe:	82,5 KB
ID:	170911   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	973
Größe:	87,5 KB
ID:	170912   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	991
Größe:	84,8 KB
Hits:	958
Größe:	84,2 KB
ID:	170914   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	969
Größe:	72,6 KB
Alt 15.11.2009, 17:55
Vize Admiral
und noch zwei....
Hits:	983
Größe:	67,8 KB
ID:	170916   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	987
Größe:	72,4 KB
Alt 15.11.2009, 17:57
Benutzerbild von Carlson
Carlson Carlson ist offline
Und heute rostet ein Benz nach 2-3 Jahren auf der Straße...
Alt 15.11.2009, 17:58
Benutzerbild von Hansel
Hansel Hansel ist offline
Boot: Wellcraft 192 classic
1.323 Danke in 527 Beiträgen
Wo ist das Teil denn aus dem Teich gefischt worden?
Hansel
Alt 15.11.2009, 17:59
Benutzerbild von divefreak
Bauen den auch die Russen?
BTW das ist der "berühmte" T34 ein mittlerern Kampfpanzer mit 76mm Geschütz, die späteren hatten 85mm um die deutschen Tiger und Panther knacken zu können
MFG René
Alt 15.11.2009, 18:01
Benutzerbild von nordic
nordic nordic ist offline
Steht doch da.
Bei Johvi in Estland.
Gruß Karl-Heinz
Alt 15.11.2009, 18:02
Steht doch in dem Text: T34/76A
Alt 15.11.2009, 18:04
Entschuldige bitte das man fragt
Hansel
Alt 15.11.2009, 18:09
Vize Admiral
Ja klar steht das da aber wenn mal mal googelt, sieht der so aus:
Kann mich aber auch täuschen
Hits:	917
Größe:	79,5 KB
Dafür ist ein Forum doch da.
Wusste garnicht, dass die Wehrmacht auch gekaperte Fahrzeuge einsetzte.
Gruß Karl-Heinz
Benutzerbild von Dirk H.
Dirk H. Dirk H. ist offline
Das muss ein verflucht Sauerstoffarmer See sein oder der Panzer hat ziemlich tief im Faulschlamm gesteckt das der nicht gerostet ist
ostfriesische Grüße,
Dirk H.
Fast fertig: Die "Tosa"
Alt 15.11.2009, 18:11
Böse Zungen behaupten mehr als Eigene....
Die haben anze Divisionen und Armeen mit Beutefahrzeugen ausgerüstet....
Oder Beutefahrzeuge umgerüstet zb zu Selbstfahrlafetten etc
MFG René
Alt 15.11.2009, 18:12
Vielleicht ist das der Ur-Trabant.
Pappe hält ewig.
Gruß Karl-Heinz
Alt 15.11.2009, 18:14
Preußenbengel
Pappe hält ewig.
das ist ein Gerücht
Alt 15.11.2009, 18:17
Das Bild zeigt nen T34/76 Modell 1940
Der geborgene ist ein Model 1942 oder Model T34/76F
Das Modell 1942 wurde aufgrund der Frontberichte stark überarbeitet. Der Turm war nun sechseckig, standardmäßig gegossen und besaß keinen Überhang mehr. Die große Luke die dem Kommandanten die Sicht versperrte wurde gegen eine zweigeteilte Luke gewechselt. Die Bughalterung für das MG wurde überarbeitet, um den Einsatz desgleichen zu verbessern. Um auf die neuen deutschen Panzer zu reagieren, wurden nun zusätzliche Panzerplatten verschweißt. Des weiteren wurden die Kraftstofftanks vergrößert.
Der T-34 F hatte als einziger T-34 mit der 76 mm Kanone eine Kommandantenkuppel. Die wichtigste Erneuerung war aber die Verbesserung der Antriebskomponenten. Es wurde nun ein Fünfganggetriebe anstatt eines Vierganggetriebes verwendet. Des weiteren wurde die gesamte Mechanik überarbeitet.
Es wurden aber nicht mehr viele F Modelle gebaut, da bald klar wurde, dass die 76 mm Kanone den deutschen Kanonen nicht mehr gewachsen war. Die Entwicklung einer stärkeren Bewaffnung war die Folge.
MFG René
Alt 15.11.2009, 18:31
Picton14ft Picton14ft ist offline
5.495 Danke in 1.377 Beiträgen
saubermachen, motor und tank reinigen und losfahren.
Alt 15.11.2009, 18:32
omas gurkenfass omas gurkenfass ist offline
Boot: p16/xr2
2.651 Danke in 1.299 Beiträgen
omas gurkenfass eine Nachricht über ICQ schicken
... de bon jovi is aus estland ?
... aha, des ja was ganz neues
Alt 15.11.2009, 18:33
Du hast "den Krieg gewinnen" vergessen...
MFG René
Alt 15.11.2009, 18:36
Benutzerbild von Tequila
Tequila Tequila ist offline
Boot: nur noch `n Schlauchi
6.338 Danke in 2.086 Beiträgen
Bei uns im Dorf wurden vor ein paar Jahren die Fischteiche abgelassen. Da lag ein 911er Porsche drin der mehr als 10 Jahre zuvor in Köln gestohlen wurde. Als man den rausgezogen hatte, sah er noch ganz brauchbar aus - bis auf die Tatsache, dass die Feuerwehrtaucher die Seitenscheiben eingeschlagen und eine Kette durch den Innenraum gezogen hatten um den 911er rauszuziehen
* Heinz *
Alt 15.11.2009, 18:40
Benutzerbild von Liebertee
Liebertee Liebertee ist offline
Boot: Catboot + Pacific Seacraft 25+Viksund 27
2.337 Danke in 869 Beiträgen
Is aber eigentlich schon älter, die Geschichte......
Gibbet auch ein Filmchen von.......http://www.youtube.com/watch?v=5x9GfYdVftw
Teil 2 http://www.youtube.com/watch?v=2ZHVg...eature=related
Teil 3 http://www.youtube.com/watch?v=HBK3Z...eature=related
Alt 15.11.2009, 19:04
Vize Admiral
Soso Kollege und warum hast du das bisher für dich behalten und deine Forumsfreunde nicht dran teilhaben lassen???
Alt 15.11.2009, 19:17
Benutzerbild von pottkieker
pottkieker pottkieker ist offline
Boot: Treckerreifenschlauchi
4.870 Danke in 1.339 Beiträgen
Vieleicht wollte er ihn ja kaufen
Gruß Hans
Folge dem Fluß und finde das Meer
Alt 15.11.2009, 20:57
Die graben da wohl öfter sowas aus...... http://www.youtube.com/watch?v=V0zfy...eature=related
Und auch nicht im schlechtesten Zustand.....
Alt 15.11.2009, 21:21
Dirk Dirk ist offline
Boot: Saga 27AC
Behaupten ist gut............mehr ist auch nicht dran.
Und böse Zungen lügen fast immer.
Der T34 war ein Massengut, der Grund warum die russischne Streitkräfte die großen Panzerschlachten auch gewonnen haben. Die Militärdoktrin der Russen hieß: Quantität vor Qualität, heute würden wir sagen 'Masse statt Klasse'. Galt noch vor einigen jahren genauso.
In jedem Krieg wurde Beutefahrzeugj eingesetzt, aber nie in Größenordnungen, das sind Stammtischlegenden.
Was aber wahr ist: der damalige fast legale "Technologietransfer" von Deutschland nach Russland.
So wurden Rüstungsgüter, die die Wehrmachtsanforderungen nicht erfüllten, schnell mal ins Ausland verkauft. Heinkel hat seine Flugzeugentwicklungen so versilbert, Bosch seine Einspritzpumpen (wie hier im T34).............und und und.
Gruß Dirk
SAGA 27 AK mit Yanmar 4JHE
Alle Zeitangaben in WEZ +1. Es ist jetzt 17:21 Uhr.
