Moin zusammen
Erst mal einen schönen Tag euch allen . Ich bin der neue. Ich habe eine frage bezüglich der befestigunglöcher zum durchbolzen des Aussenborders Ich möchte von suzuki dt 40 cbj 1990 auf evinrude etec 50 ps bj 2004 umsteigen . Stimmen die Bohrabstànde dieser motorplatten ùberein ? Bis später chris |
Nein die sind nicht gleich.
LG |
Danke fürs schnelle beantworten
Moin whaler woher kannst du das so schnell bestimmen. Gibt es hierüber listen oder àhnliches?
Lg |
Weil ich neulich einen 40er suzuki montiert habe.
Gruß Martin |
Vielen Dank
Was ist mit der Aussage Found this for those that were interested.
"It is believed that the hole arrangement currently in use by most engine manufacturers follows these dimensions: •The top pair of holes are spaced 12 and 7/8-inch on center; each hole is 6 and 7/16-inch from the engine bracket centerline. •The bottom pair of holes are spaced 9 and 7/8-inch on center; each hole is 4 and 15/16-inch from the engine bracket centerline. •The spacing between the top and bottom pair of holes is 8-inches on center. •The centerline of the top holes is 2-inches below the top of the engine bracket. The holes in the transom should be 1 and 7/8-inch below the top of the transom. In no case should they be closer than 1 and 3/4-inch to the top of the transom. Holes located 1-7/8-inch below the top of the transom will produce a slight gap between the transom and the engine mounting bracket. This gap can be filled with an appropriate spacer or shim to help bear the engine's weight onto the transom. •When locating holes on the transom, do not assume the top of the transom is a straight or true edge. Determine the transom vertical centerline by measuring equal distances from the hull's chines. Align the engine mounting holes to the true vertical centerline of the transom, not to the top edge of the transom. There is no point in drilling holes in the above pattern if they do not match those on your engine. Generally a hole template is supplied with a new engine. Absent that, a template could be made from the actual holes on the mounting bracket of an existing engine. Locate the holes as specified with respect to their position from the top of the transom." |
In our experience there are two pattern sets depending on the engine horsepower. We fit new Suzuki and Evinrude engines, and all engines in the 40 - 225 hp are the same pattern, but smaller engines have, quite logically a smaller pattern. Have a look at www.explorermarine.co.uk if you want to see the reange of boats which we build Regards |
Dein 40er hat ein Bracket für kleine Motoren.
Der Link zum 50er zeigt ebenfalls ein kleines Bracket. (ist auch nicht das genormte für größere Motoren) Du hast ja nun die Maße also was hindert Dich daran nach zu messen.
Gruß aus Berlin Jörg ![]() Es wird immer jemand geben, der etwas gutes etwas billiger und schlechter herstellt, als bisher. |
| Neuer Motor oder Alten Motor Aufarbeiten? | StephanK14 | Motoren und Antriebstechnik | 9 | 22.03.2009 20:28 |
| Motor spülen Frostschutz wenn Motor nicht läuft | tommyc | Motoren und Antriebstechnik | 7 | 22.09.2008 21:31 |
| Wie schwer ist es einen Auto Motor zu marinisieren. Audi 1,8T Motor | kaptainkoch | Motoren und Antriebstechnik | 8 | 24.06.2008 22:04 |
| Salzwasser IM Motor - Motor im Eimer aber super Hilfe! | alex_s_ooe | Motoren und Antriebstechnik | 12 | 20.10.2007 19:15 |
| Unterschied vom 25 PS Motor und 20 PS Motor Yamaha | Runn3rPJ | Technik-Talk | 12 | 14.06.2006 16:40 |
