Alt 29.05.2011, 06:20
Benutzerbild von tom03
tom03 tom03 ist offline
Boot: Bayliner 2655
122 Danke in 95 Beiträgen
Standard Coast guard Plakette
Auf der coast guard Plakette meines Regal steht was von Basic Flotation. Heisst das dass es unsinkbar ist ?
Lg Tom
Hits:	94
Größe:	33,2 KB
Alt 29.05.2011, 07:56
Boot: Bayliner 2655
hab schon was gefunden...
83.105 - Quantity of flotation required (a) Each boat must have enough flotation to keep any portion of the boat above the surface of the water when the boat has been submerged in calm, fresh water for at least 18 hours and loaded with:
(1) A weight that, when submerged, equals two-fifteenths of the persons capacity marked on the boat;
(2) A weight that, when submerged, equals 25 percent of the dead weight; and
(3) A weight in pounds that, when submerged, equals 62.4 times the volume in cubic feet of the two largest air chambers, if air chambers are used for flotation.
http://www.uscgboating.org/regulatio...n_part1_e.aspx
Alle Zeitangaben in WEZ +1. Es ist jetzt 02:10 Uhr.
