Alt 04.03.2025, 07:26
Benutzerbild von Totti-Amun
13.487 Danke in 4.736 Beiträgen
Standard Die NATO bittet um Mithilfe BALTIC SENTRY REPORTING INFORMATION
Die Nato bittet die zivile Schifffahrt und Sportbootfahrer im Ostseeraum um Mithilfe und Meldung bei auffälligen Schiffen und Schiffsbewegungen.
Baltic Sea - Waters of Skagerrak, Kattegat, Baltic Sea, Gulf of Finland, Sea of Bothnia and Bay of Bothnia.
Due to recent damages to undersea infrastructure in the Baltic Sea region, NATO forces are conducting BALTIC SENTRY to monitor and respond to threats to undersea infrastructure.
Vessels observing suspicious behavior or incidents are encouraged to report to the NATO Shipping Centre at +44 1923-956574 or report the incident via an email to the address: ​info@shipping.nato.int. Your email should include:
- Name and Flag of your vessel
- Telephone number (INMARSAT) of your vessel
- Position, date and time of the irregular or suspicious incident or behavior observed
- As detailed description of the incident or behavior as possible
(Other means of documentation such as screen shots from radars, ECDIS photos, and recordings of communication are much appreciated).
Vessels reports will be used as part of the operational monitoring in the Baltic Sea. Engaging in reporting of this kind to the NATO Shipping Centre will not in any way cause any delays or other inconveniences.
Examples of suspicious observations, behavior or incidents are:
- Vessels lacking anchor(s).
- Vessels doing speed with an anchor out (suspected to drag its anchor).
- Vessels reducing speed to an abnormal level over or close to known undersea infrastructure.
- Vessels having an abnormal sail pattern over or close to known undersea infrastructure.
- Unannounced diving activities over or close to known undersea infrastructure.
NATO Shipping Center will acknowledge all reporting received.
Check out:
Surf-Forum.com
Windcraft-Sports.com
Autoscooter-Forum.com
Alt 04.03.2025, 11:54
schimi schimi ist offline
10.042 Danke in 4.216 Beiträgen
INFORMATIONEN ZUR MELDUNG VON OSTSEEWÄCHTERN
Ostsee - Skagerrak, Kattegat, Ostsee, Finnischer Meerbusen, Bottnisches Meer und Bottnischer Meerbusen.
Aufgrund der jüngsten Schäden an der unterseeischen Infrastruktur im Ostseeraum führen die NATO-Streitkräfte BALTIC SENTRY durch, um die unterseeische Infrastruktur zu überwachen und auf Bedrohungen zu reagieren.
Schiffe, die verdächtiges Verhalten oder Zwischenfälle beobachten, werden gebeten, sich beim NATO Shipping Centre unter +44 1923-956574 zu melden oder den Vorfall per E-Mail an die folgende Adresse zu melden info@shipping.nato.int. Ihre E-Mail sollte Folgendes enthalten:
- Name und Flagge Ihres Schiffes
- Telefonnummer (INMARSAT) Ihres Schiffes
- Position, Datum und Uhrzeit des beobachteten unregelmäßigen oder verdächtigen Vorfalls oder Verhaltens
- Möglichst detaillierte Beschreibung des Vorfalls oder Verhaltens
(Andere Dokumentationsmittel wie Bildschirmfotos von Radargeräten, ECDIS-Fotos und Aufzeichnungen der Kommunikation sind sehr willkommen).
Die Berichte der Schiffe werden als Teil der operativen Überwachung in der Ostsee verwendet. Eine derartige Meldung an das NATO-Schifffahrtszentrum wird in keiner Weise zu Verzögerungen oder anderen Unannehmlichkeiten führen.
Beispiele für verdächtige Beobachtungen, Verhaltensweisen oder Vorfälle sind:
- Schiffe ohne Anker(n).
- Schiffe, die mit ausgefahrenem Anker fahren (und bei denen der Verdacht besteht, dass sie ihren Anker schleppen).
- Schiffe, die ihre Geschwindigkeit über oder in der Nähe bekannter unterseeischer Infrastrukturen auf ein anormales Niveau reduzieren.
- Schiffe mit anormalen Fahrmanövern über oder in der Nähe bekannter unterseeischer Infrastrukturen.
- Unangekündigte Tauchaktivitäten über oder in der Nähe bekannter unterseeischer Infrastrukturen.
Das NATO Shipping Center wird alle eingegangenen Meldungen bestätigen.
Alt 04.03.2025, 12:41
Boot: Vetus Bellus 1200
16.488 Danke in 4.476 Beiträgen
Bleibt noch die Feststellung, dass Sportboote nicht erwähnt wurden und vermutlich auch nicht gemeint wurden. Welches Sportboot hat schon Inmarsar? Gleichwohl wären sicher auch entsprechende Meldungen von Sportbooten nicht unerwünscht.
Gottes sind Wogen und Wind,
Segel aber und Steuer,
daß ihr den Hafen gewinnt,
sind euer.
Gorch Fock
Alt 04.03.2025, 12:48
Die Yacht.de fühlt sich auch angesprochen und gewichtet anders als du. Aber welche Relevanz hat das Magazin schon...?...
https://www.yacht.de/reisen-chartern...r-um-mithilfe/
Zitat von Yacht.de
NATO bittet Sportskipper um Mithilfe
Zusätzlich unternimmt die NATO aber den bisher ungewöhnlichen Schritt, andere Seefahrzeuge - also auch zivile Yachten und Sportboote - ebenfalls um Mithilfe zu bitten. In einem offiziellen Aufruf, der inzwischen auch von Ländern wie Schweden über die nationalen Nachrichten für Seefahrer (notices to mariners) weiterverbreitet wurde, wird der Vorgang erklärt.
Gemeldet werden sollen demnach “verdächtiges Verhalten und verdächtige Ereignisse” wie Fahrzeuge, die in Fahrt ihren ausgebrachten Anker mitschleifen, bei denen ein Anker fehlt, oder die die Fahrtgeschwindigkeit auf ungewöhnliche Weise verringern oder häufige Kurswechsel vollziehen (besonders, wenn sich laut Seekarte Unterwasserstruktur in der Nähe befindet). Gleiches gilt für Tauchgänge in solchen sensiblen Bereichen.
Totti
Check out:
Surf-Forum.com
Alt 04.03.2025, 12:49
Benutzerbild von Desertbyte
Boot: Aquamar Bahia 20
Rufzeichen oder MMSI: OEX3621
2.803 Danke in 1.123 Beiträgen
Na ich denke wenn sich die Meldung auszahlt, dann nehmen die auch eine banale Email.
Wobei so eine Inmarsat-Anlage mit Radom auf einem 6m Boot: Das wär schon was
LG, Roland
“Es ist eigentlich schon alles gesagt, nur nicht von jedem!” (Karl Valentin)
Alt 04.03.2025, 13:12
Didi 66 Didi 66 ist gerade online
Boot: Altena
533 Danke in 182 Beiträgen
mal wieder die typisch deutsche Diskussion was alles nicht geht!
Ich kann allen Zweiflern (aus meiner beruflichen Erfahrung heraus), versprechen, dass wenn ein Sportboot einen solchen Vorfall (wie in dem Aufruf beschrieben) meldet, diesem nachgegangen wird, egal auf welchen Weg die Meldung eingegangen ist.
Gruß Didi
Alt 04.03.2025, 13:23
Benutzerbild von Flieger
Flieger Flieger ist offline
Boot: Doriff 666
2.051 Danke in 1.020 Beiträgen
warum nicht einfach mal die Griffel still halten?
Bernhard
Alt 04.03.2025, 14:49
Die Überschrift der Yacht ist irreführend.
Interessanterweise geht es da um speziell um Segler. Wenn man die Meinung der Yacht schon gewichten will, dann sind Motorbootfahrer nicht gemeint.
Die zivile Schifffahrt ist angesprochen. Natürlich gehören Yachten auch dazu. Aber weder Segler noch Motorbootfahrer wurden hier direkt angesprochen.
Daher sind die Behauptungen, bzw Überschriften falsch, die den Eindruck erwecken, als würden o.G. hier direkt angesprochen.
Fehlt nur noch der Hinweis, dass Passagiere von Kreuzfahrtschiffen um Ausschau gebeten werden.
Offenbar passt meine Sicht der Dinge hier Einigen nicht. Ist mir Wurscht. Sorry.
sind euer.
Gorch Fock
Alt 04.03.2025, 14:55
Sayang Sayang ist gerade online
2.842 Danke in 1.386 Beiträgen
Bleibt noch die Feststellung, dass Sportboote nicht erwähnt wurden und vermutlich auch nicht gemeint wurden. ...
Du hast wohl Recht, aber sicherlich werden auch Informationen von Sportbooten angenommen, obwohl die NATO solche nicht erwaehnt hat (wenn sie jetzt in ihrem Sprachgebrauch Sportboote unter “vessel” fuehrt, ist das an mir vorbeigegangen.) Auch die Notices to Mariners richten sich an ausruestungspflichte Schiffe, obwohl sie Sportbooten zugaenglich sind.
Alt 04.03.2025, 15:42
Sealord37 Sealord37 ist offline
Boot: Wiking Festival
1.831 Danke in 726 Beiträgen
Woher weiß ich, wo sich unterseeische Infrastruktur befindet und welche Tauchaktivitäten unangekündigt sind?
Ich habe z.B. noch nie irgendeine Tauchaktivität angekündigt und wüsste auch nicht, dass oder wo man das müsste. Zumindest, wenn es sich um sportliche Tauchaktivitäten handelt, als welche man eigentlich jede tarnen könnte.
Will sagen, der normale Böötchenfahrer weiß es vermutlich meist gar nicht, wenn er Zeuge einer verdächtigen Aktivität wird.
Alt 04.03.2025, 15:51
Unterseeische Infrastruktur erkennt auch der Laie an Schiffen, die so wohl den Anker draußen haben als auch ein Kielwasser, weil sie in Fahrt sind.
sind euer.
Gorch Fock
Alt 04.03.2025, 15:55
… oder in die Seekarte gucken ….
Alt 04.03.2025, 15:57
Diese Seekabel sind in den Seekarten ersichtlich, es gibt auf See Seekartenpflicht für die Sportbootfahrer.
Wenn Taucher im Wasser sind, sieht man das für gewöhnlich an der entsprechenden Beflaggung.
Totti
Check out:
Surf-Forum.com
Alt 04.03.2025, 16:23
Ist da jedes Kabel eingezeichnet? Hätte gedacht, dass sowas nicht immer öffentlich ist.
Alt 04.03.2025, 16:26
Totti
Beflaggung ist zwar ne tolle Sache, macht aber auch nicht jeder. Auf der anderen Seite wäre es auch möglich, das Saboteure eine Taucherflagge setzen.
Alt 04.03.2025, 16:42
Nein, es werden wahrscheinlich nicht alle Seekabel eingezeichnet. Geheime Kabel, die nicht eingezeichet sind, werden aber offiziell auch nicht beschaedigt, da sie dann nicht mehr geheim sind. Alle anderen Kabel, wie auch Pipelines, werden eingezeichnet, und es wird gleich ein Ankerverbot (meist 200 bis 500 m vom Kabel) mit festgelegt (und auch eingezeichnet)
Um die nicht eingezeichneten Kabel muss man sich also keinen Kopf machen.
Alt 04.03.2025, 16:58
… Will sagen, der normale Böötchenfahrer weiß es vermutlich meist gar nicht, wenn er Zeuge einer verdächtigen Aktivität wird.
Sicher sind nicht alle verdaechtigen Aktivitaeten als solche erkennbar, aber wenn ich, als Beispiel, ausserhalb der Hoheitsgebiets ein Frachtschiff in Fahrt mit Anker im Wasser sehe, oder Taucher, ist das fuer mich schon verdaechtig.
Benutzerbild von Federball
5.486 Danke in 3.099 Beiträgen
Interessanterweise geht es da um speziell um Segler. Wenn man die Meinung der Yacht schon gewichten will, dann sind Motorbootfahrer nicht gemeint....
Na ja, wie viele MoBos sind denn auf der offenen Ostsee unterwegs? In Häfen liegen ganz selten welche, + die müssen ja da hingekommen sein, aber sonst : fast Null.
Sollte ich mal ein MoBo haben, will ich die Statistik verbessern
Grüße, Reinhard
Alt 04.03.2025, 17:01
Die Ostsee rund um Schweden ist stark frequentiert von Sportbootfahrern.
Es geht ja nicht nur um den Bereich um Gotland.
Totti
Check out:
Surf-Forum.com
Alt 04.03.2025, 17:30
Boot: Altena
Hallo Leute,
ich kann mich da nur wiederholen, meldet einfach wenn Euch irgendetwas komisch vorkommt, egal ob an die angegebenen Stellen, oder auch an die Bundespolizei See. Keiner reißt Euch den Kopf ab und wenn der Sachverhalt bekannt ist, dann ist das so. Wenn ich mit meinem MoBo im April von meinem Winterlager in Berlin nach Stralsund fahre, mal sehen je nach Wetterlage auch über die Ostsee, werde ich auch wenn mir was auffällt eine Meldung absetzen.
@Oldskipper: Ich toleriere und akzeptiere grundsätzlich andere Meinungen und hatte bestimmt nicht die Absicht hier jemand persönlich anzugreifen.
Gruß Didi
Alt 04.03.2025, 18:03
Benutzerbild von caveman
caveman caveman ist gerade online
Boot: Pedro Donky 37
Rufzeichen oder MMSI: DC9068
5.282 Danke in 769 Beiträgen
Mist, dass die erst jetzt damit um die Ecke kommen... Hätte ich das vorher gewusst, dann hätte ich die Pathfinder nicht zu Pedro sondern zu HDW oder Lürssen gebracht. Dann hätten die sich da über Winter so richtig austoben können, was 3D-Sonar, IR Sensoren, Antennen für alle möglichen Frequenzen, Radar upgrade, usw angeht.
Ich hätte mich danach dann freiwillig für das Sommerkontingent gemeldet um Haff, Boddengewässer und Bornholm zu patroullieren. Gaaaanz unauffällig, natürlich
Nuiszuspäd...
Beste Grüße,
Phil
Alt 04.03.2025, 18:39
Nuiszuspäd...
Da bleibt dann nur der Kabelfinder aus dem Baumarkt.
sind euer.
Gorch Fock
Alt 04.03.2025, 18:53
Benutzerbild von Startpilot
Boot: MAB 12
12.730 Danke in 4.500 Beiträgen
Bis #20 waren die Beiträge der angespannten internationalen Situation angepasst.
Mit Blick in die Nachrichten sehe ich wenig Spielraum für humoristische Interpretationen. Leider.
Gruss, Dirk
Alt 07.03.2025, 19:34
Boot: Sollux 850
Rufzeichen oder MMSI: DC 3244
5.359 Danke in 1.898 Beiträgen
So ganz neu ist die Bitte um Aufmerksamkeit hinsichtlich verdächtiger Schiffsbewegungen nicht. Da gab es mal ein sowjetisches U-Boot, dass auf Grund navigatorischer Fehler bei einem Spionageauftrag vor dem schwedischen Karlskrona auf harten skandinavischen Granitfels lief.
War natürlich sehr peinlich für den Kapitän obwohl jeder wusste, dass auch die Anderen spionieren. In Schweden waren daraufhin alle Seefahrer aufgerufen, verdächtige Umstände zu melden. Das machen die auch bis heute und für die ist es eine Selbstverständlichkeit.
Sollte es für uns also auch sein....
Gruß und gute Fahrt
Kapitaenwalli
Alt 10.07.2025, 18:17
Boot: Sollux 850
Vorgestern Øresund Nordausgang. Portugiesisches NATO Warship bittet um Meldung verdächtiger Schiffsbewegungen.
Sweden Traffic weist zu Beginn der Navigationsmeldungen darauf hin, dass im gesamten Baltikum mit GNSS Störungen gerechnet werden muss.
Danke an alle die acht geben und danke den Soldatinnen und Soldaten für ihren Einsatz.
Gruß und gute Fahrt
Kapitaenwalli
Slippen in Düsseldorf Nato Rampe ACHTUNG! Bayliner 1802 Allgemeines zum Boot 56 15.06.2023 16:00
Erfahrungen mit der Nato-Rampe in Duisburg? oskar-lima Deutschland 12 02.07.2019 19:36
Nato Rampe Rhein Orange geschlossen pasic Allgemeines zum Boot 63 23.07.2013 14:37
Sperrung Nato Straße in Gernsheim lalao0 Allgemeines zum Boot 3 18.06.2013 17:48
Alle Zeitangaben in WEZ +1. Es ist jetzt 13:22 Uhr.
