| Restaurationen Refits, Lackierungen, GFK-Arbeiten, Reparaturen und Umbauten von Booten aller Art. |
Have totally renovated a Wiking filius
It has become a jewelery But I do not get the boat to go faster than 15kmh The engine is in good condition and nothing wrong with it propeller is original. I have probably to put some weight on the boat, but did not think it was so much. Do I need to buy a new motor??? "Haben völlig ein Wiking filius renoviert Es war eine Kette Aber ich glaube nicht, das Boot schneller als 15kmh gehen Der Motor ist in gutem Zustand und nichts falsch mit ihm Propeller ist original. Ich habe genug, um etwas Gewicht auf dem Boot setzen, aber nicht glaube, es war so viel. Brauche ich einen neuen Motor kaufen??" |
Hi olstad,
have you som photos from the engineroom ? If it is an 3-cylinder 2-stroke-engine fro an Wartburg, he has 45 or 50hp. I think, the boot goes up to 40 km/h with them. Photo: This is an Wartburg-engine in my Lotos I with reversegearbox.
Gruß Steffen Der Thread für die Poseidon-Fahrer: http://www.boote-forum.de/showthread.php?t=220680 Der Zweedaggtmief, der Zweedaggtmief, der krabbelt in der Nase tief...... |
Hello!
Thanks for the reply! Have Wartburg engine new coil, new ebeza box new plugs, caps and the ignition is set. I do not know what to do ![]() it can not be anything wrong with the propeller? Do not want to buy a new engine 1 costs too much here in Norway 2 will have the original and like the sound. |
Hello Olstad,
Your motor is a 50 Hp model and it should easily bring 40 to 43 Km/hour. The first thing you will have to check if it runs on all 3 cilinders. If so, the motor should run 4000 RPM at full speed. I think you have the wrong propeller on it. It looks like a propeller that i use on my 70 Hp Melkus/Wartburg motor. Try a propeller with "rounded" blades instead on the squere ones. Also the propeller "Pitch" is very important. You can probably find the propellers rather cheep on E bay. de. Regards, Taco. |
If you need a new: I currently sell a motor.
It was removed after a short usage and converted to two circuit cooling. Then he was professionally conserved and stored. |
Hello Olstad,
your propeller has the wrong direction of rotation. On the Wartburg with the LEWO-gear you must be use a lefthand rotation prop. Regards Stefan |
Really??
anyone know where I can find such a propeller?? |
Hi olstad,
look at the left Side of my photo there are 2 original propeller for my Lotos. ~31km/h at 4000rpm with Lewo 20 :http://www.maschinenbau-lehmann.de/FrmSets/Down_02.html ( Bootswendegetriebe Lewo20/25 pdf download http://www.maschinenbau-lehmann.de/D...e%20-%20A4.pdf ) Your filius runs better, the Lotos weighs ~ 600kg , and is 5,5m x 2,07m - filius 4,7mx1,6m ? 400kg ? The ..arbor? in your steve tube is an 22mm arbor, korrectly ? Information to your Filius can you find hier: http://www.oldieboote.de/navigation/forum.html and : http://www.oldieboote.de/navigation/...ng/filius.html I don't know, whether a propeller from a Lotos can good work with your boat..... Buy a propeller.......hm.....ebay germany, and search "Propeller & Wartburg or DDR" ( german democratic republic ), use in this forum or in the oldiebooteforum the market. Greets
Gruß Steffen Der Thread für die Poseidon-Fahrer: http://www.boote-forum.de/showthread.php?t=220680 Der Zweedaggtmief, der Zweedaggtmief, der krabbelt in der Nase tief...... Geändert von Halstrom (08.12.2012 um 14:41 Uhr) |
Gruss, Taco. |
is this the right way?
http://www.ebay.de/itm/3-Blatt-Prope...item3ccc0a7c75 (PaidLink) |
Hallo Taco,
ich habe die gleiche Kombi Wartburg/Lewo im Kajütboot. Und Wartburg sind Linksläufer, beim Lewo wird in Vorausfahrt nur das Kupplungs- paket geschlossen, keine Drehrichtungsänderung oder Untersetzung wie beim Lunze-Getriebe. Das Lewo ist im Rückwärtsgang leicht, 1,2:1,untersetzt. Max. Drehzahl für Vorwärts ist 4500U/min, für Rückwärts nur 1000U/min!!!! Hoffentlich hat er dem Teil nicht schon das Genick umgedreht! Grüße Stefan
Look at item 150961561598.
I may translate for our scandinavien member:
"Hi Taco, I have the same combination of Wartburg and Lewo in my cabin cruiser. The Wartburgs are of left-hand rotation. In forward speed the Lewo simply engages the clutch without any gear reduction. The Lunze gearbox is different in having a gear reduction and a change in rotation. In reverse speed the Lewo features a small gear reduction of 1.2:1. The maximum speed in forward speed is 4500 1/min, in reverse 1000 1/min. I hope he has not damaged the part yet. Regards Stefan"
Beste Grüße John |
I have not run much with the boat
I had some other problems earlier. Therefore, completely new electrical system. a small short circuit destroyed "3 Geber" Changed everything before I figured it out So just test driven a few trips. tested the rpm, and everyhing is good I have an extra transmission so I can switch if I need to |
