Zurück   boote-forum.de - Das Forum rund um Boote > Dies & Das > Werbeforum
Werbeforum Hier kann nach Lust und Laune geworben werden. Bitte auch hier die Regeln und Nutzungsbedingungen beachten!
Alt 25.06.2012, 12:05
Benutzerbild von Harleyschrotter
Harleyschrotter Harleyschrotter ist offline
Boot: Holzschachtel
558 Danke in 249 Beiträgen
Standard 4 Blatt Edelstahlprop
Verkaufe folgenden,
unbeschädigten rechtdrehenden 4 Blatt Edelstahlprop:
Hydromotive HC-CL19R
19" Steigung, 38cm oder 14,96 Inch Durchmesser
Nabe passt auf Alpa und Bravo Antriebe
Hier ein Auszug vom Anbieter:
Hydromotive Quad IV
Monster Marine -> Props -> Hydromotive Quad IV
The Intimidator Quad IV propellers are designed primarily for single and twin engine sport boats. Boats with good natural bow lift, pad bottom boats, both single and double ventilated step bottom hulls and air entrapment hulls are perfect candidates for the Intimidator Quad IV propellers. Unmatched mid-range acceleration and blistering top speeds are trademarks of the Quad IV in both the pleasure and race arenas. These propellers are available in both right-hand and counter-rotation, and pitch ranges in every inch from 19" to 34". At 15 1/2" in diameter, these propellers perform quite well with high "X" dimensions and are currently manufactured with a built-in flare ring to improve hole-shot and mid-range cruise speed. The higher pitches are also available, from 28" to 34", in 16" diameter with slightly more blade area, allowing for extremely high "X" dimensions. Quad IV propellers are polished, balanced and more importantly, are all heat treated. Our manufacturing techniques and refinements over the years have greatly increased blade strength and fatigue resistance in some of the most punishing applications as is evidenced in our success in off shore racing. These propellers are available in the standard configuration for the Mercury TRS and Bravo drives as well as for the Bravo I XR drive with the large shaft. Our success in Factory I and II racing and our current kilo records assure you that our Intimidator Quad IV propellers have no equal.
ITEM # DESCRIPTION PRICE COLOR QTY 569 Hydromotive Quad IV $593.95
Preis: 270 Euro.
Anfragen bitte per PN oder E-Mail
Gruß Thomas
Hits:	128
Größe:	126,2 KB
ID:	370962   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	126
Größe:	125,7 KB
ID:	370963   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	112
Größe:	134,2 KB
Hits:	110
Größe:	54,5 KB
Geändert von Harleyschrotter (25.06.2012 um 12:13 Uhr)
Alt 27.06.2012, 08:53
Boot: Holzschachtel
Kein Bedarf?
Alt 27.06.2012, 08:57
Benutzerbild von JPCool
JPCool JPCool ist offline
Zitat von Harleyschrotter Beitrag anzeigen
Kein Bedarf?
Kennt warscheinlich kaum einer.
Hilfreich wäre noch die Angabe, auf was für einem Boot das Teil gelaufen hat.
Alt 27.06.2012, 10:15
Benutzerbild von D!RK
D!RK D!RK ist offline
Boot: Coronet 24 Cabin
Rufzeichen oder MMSI: DO2XLT
47 Danke in 41 Beiträgen
auch der Umfang wäre hilfreich
nicht nur die Steigung.
Bye
Dirk
"Brain 1.0 (die Vollversion, nicht die limitierte Sharewarevariante, die viele im Einsatz haben) ist wohl immer noch der beste Schutz."
Alt 27.06.2012, 10:30
Benutzerbild von slowmotionboote
slowmotionboote slowmotionboote ist offline
Boot: Hille Jaguar
787 Danke in 160 Beiträgen
Welche Narbe bzw Aufnahme hat das gute Stück.
Flo-Torq 1 oder ? bzw fest eingepresst
bzw passt das auf den TR mit dicker Welle?
gruss andre
Schreibfehler bitte ich zu Entschuldigen.
Bin Staatlich geprüfter Legasteniker,Beglaubigte Abschrift kann gegen Erstattung der Gebühren vorgelegt werden.
Alt 27.06.2012, 11:07
Verkaufe folgenden,
Gruß Thomas
Steht doch da
Alt 28.06.2012, 00:25
Boot: Holzschachtel
Umfang ?!?
Noch nie gehört das irgendwo der Umfang angegeben wird.
Soll ich den wirklich messen?
Ansonsten wie bereits beschrieben,
passt auf Bravo, wahrscheinlich auch auf nen Alpha (wenn der Durchmesser nicht zu groß ist)
und auf TRS Antriebe.
Der Prop war auf einer Sea Ray Pachanga.
Gruß Thomas
Alle Zeitangaben in WEZ +1. Es ist jetzt 11:51 Uhr.
