Alt 15.01.2020, 13:47
Shekastui Shekastui ist offline
Boot: Kazanka-M, nearly all Soviet boat engines; Mercury 2.5; Forelle 6
42 Danke in 8 Beiträgen
Standard Found extremely rear and old (1932) soviet boat engine P-5 "Pioneer"
Hello to everyone. Unfortunately I don't know German language, that's why I will write in English. I'm from Russia and once your forum helped me a lot with the information on Forelle 6 engine. Now I feel obliged to share with you the photos of really rear boat engine, I've found recently. For more than 10 years I've been collecting soviet boat engines. Now I have 20 different model produced after WWII. The oldest one was produced in 1953. But in september I was lucky to find the engine produced in 1932 or 1933! It is called P-5 "Pioneer" and it was the first boat engine to be produced in USSR. it was produced in 1932-1933 by guild of deaf and dumb people in Moscow. No more than 2000 engines were produced. I was lucky to find one in Elat'ma town of Ryazan' district in Russia. Probably this engine is the only one that survived.
Here are the only images of that engine I've found, except for my own photos. 1933 photo from the factory:
The image from an old soviet book:
This is how the engine looked like when I brought it to my house:
One piston refused to leave the cylinder. I had to keep it in diesel fuel for one month before I was able to remove it with hydraulic lifting jack.
At last it was completely disassembled:
Then everything was washed using "Aquablast" technology:
Many parts are made from copper:
The piston that was hard to remove was completely blocked, so I had to disassemble it completely. Instead of clip rings they used corks from aluminium to fixate the stud. So I had to drill them:
The stud and the copper bearing were completely ruined:
The quality of the parts is terrible:
I've already made a new bearing, the stud is luckily similar to the studs il Lada Priora car.
One of the cylinders had a terrible looking welding, had to remove it:
At he moment all steel parts are send to powder coating, screws are send to zinc coating.
I will post the further process of restoration if you are interested. Feel free to ask any questions. I can also make posts about other soviet engines I own if you want.
P.S. The owner of the engine told me that his grandfather exchanged this engine for a horse. Hard to imagine it nowdays.))
Alt 15.01.2020, 14:27
Frank63 Frank63 ist offline
Boot: Triss 48 + Evinrude E50
Rufzeichen oder MMSI: Na, min Jung...?
379 Danke in 242 Beiträgen
Hello to Russia,
very interesting...please go on with your illustrated documentation of repair.
Regards,
Wenn`s einfach wär, könnt`s ja jeder...
Alt 15.01.2020, 15:49
Benutzerbild von Startpilot
Boot: MAB 12
12.903 Danke in 4.559 Beiträgen
In my understanding Russian people are known for their capability to repair almost everything resp. to be able to create a running engine out of scrab.
These skills are mostly forgotten in our regions due to easy consumable and cheap new parts and engines even as more and more complicated constructions.
Most of the producing companies don´t want them to be easily repaired...
Keep on with documentation of your work; my great respect!
Gruss, Dirk
Geändert von Startpilot (15.01.2020 um 15:56 Uhr) Grund: Correction
Alt 20.01.2020, 11:26
In fact you are right. But in Moscow we are facing the same problems now. I'm restoring GAZ-24 "Volga" car and it is nearly impossible to find a good carbuurator specialist in Moscow now.
I have another project with friends. We placed V8 GAZ-53 truck engine to another "Volga" car to make the replica of KGB version of that car. And I had to travel 450 km to Ivanovo town to balance the crankshaft of that engine, cause nobody in Moscow could do that.
Alt 27.01.2020, 09:58
The restoration is on! The parts returned from powder coating and the screws returned from zinc coating. I started the assembly.
Using small lathe I made the corks fixating the stud in the piston.
Then I hammers them into the piston and removed the sticking out part of the cork with a Dremel.
This is how the screws look like after zinc coating:
I had to cut some new sealings:
Finished the fly wheel. It weighs 12.5 kg!!!
The "leg" is also ready:
Now I have some problems with a crankshaft. I can't press a new upper bearing on it, so I need to polish the upper part of the crankshaft. On the contrary the lower bearing won't fixate on the crankshaft. So I'll have to weld the fitting place on it and then grind it to the needed size. It will take some time.
Alt 04.03.2020, 14:34
I started the assembly. I polished the upper part of the crankshaft and the bearing pressed on it without any problems. The lower bearing i fixed with Loctite 638. Unfortunately I broke one of the piston rings, now I'm looking for someone who will be able to manufacture me a new one. Also the fly wheel is completely demagnetized and I'm looking for someone to magnetize it. The ignition system besides the magnets is alive!
Alt 07.02.2025, 10:57
Hello to everyone! I'm sorry for abandoning the topic. But I've got the work injury in april 2020, Covid and all the other crazy things happening around. However, "Pioneer" is still alive and I'm working on bringing it to life.
I sent the fly wheel to another city, where it was magnetized again and returned to me. I installed it on the engine and got the spark!
I spent more than a year looking for someone to manufacture a new piston ring and in the end I was lucky.
I succesfully assembled the whole engine, but the new rings moved too tightly inside the cylinders. So I found an electric engine and organized "cold" running-in of the engine. That helped, the engine started to rotate easily and obtained the needed inertion.
But I had absolutely no information about the needed settings of the ignition and carburator and for that reason all my attempts to start the engine failed.
Recently I've found the instruction for that engine in the library. It was published in 1934. I've been looking for it many times, but I was forming the search query in the wrong way. The word "Pioneer" was of no help, cause there were hundreds of thousands books with that word in the title. The problem was that in Russia we use "outboard motor" instead of "outboard engine" and I was looking for "outboard motor Pioneer" or for "motor Pioneer", but the title of the instruction was "Engine pioneer".
Now I know the needed settings and understand that mine were completely incorrect. So I'm wating for the warm weather to make another attemt of launching the engine.
Also I've made three videos for Youtube. The first one wiil be of no interest to you, cause I'm telling the history of the engine there in Russian. The second one is about the disassembly, but I had absolutely no experience of making videos, so the camera angles are not perfect at all. The third one shows the results of the restoration and the process of cold running-in, it might be intersting. Anyway I'll leave the links:
https://youtu.be/h9TD4cy_KO8
https://youtu.be/iTvmXDV2gR8
https://youtu.be/1oKnlakSBw0
Alt 07.02.2025, 11:00
PERA (Production Engine Remanufacturers Association) / Engine builder magazin (USA) ? Warmduscher Offshore 0 20.08.2013 15:26
Erste Messe "Beach and Boat " im Neuseenland GastMast1234 Allgemeines zum Boot 39 20.02.2009 10:43
Elbe-Revierführer 2006 und Reprint 1932 ToDi Deutschland 0 01.03.2006 18:33
Alle Zeitangaben in WEZ +1. Es ist jetzt 01:13 Uhr.
