Alt 12.06.2018, 18:25
Benutzerbild von Burnoutbrother
Burnoutbrother Burnoutbrother ist offline
Boot: Mastercraft x 25
Rufzeichen oder MMSI: 99-55-YN
336 Danke in 187 Beiträgen
Standard Wakeboard ronix el bandwagon 143 top Zustand
Ich kann nur ein Board fahren - darum geht es weg
sehr guter Zustand, wenig genutzt - leichte Spuren von der Bindung, keine Inverts, obstacles etc. nur am Boot - super softe Landungen!!
Vb 250
Next time the bros hit the lake for a casual cruise sesh, turn it into air-lifted fiesta with the Ronix Bandwagon ATR Wakeboard. This deck has nearly 10% more surface area than your average wakeboard and nearly 10% less water contact compared to them as well. It wouldn't seem favorable, but don't say anything before you try it. The end result is a large board, with Ronix s greatest sweet spot and added stability. Plus the minimal water contact makes this board ride similar to a smaller deck. The Camber in this allows you to face the wake in a more naturally balanced stance too. Time to party with grabs, flips, backrolls and the largest airs your mates have ever seen with the Ronix Bandwagon ATR Wakeboard.
ROCKER TYPE
Camber – You don't realize how much you wakeboard in the backseat body position on a traditional board until you ride camber. Now a rider drives off the wake using both legs, with a more powerful but centered snap.
SHAPE
Thin Tip/Tail Profile – Generates more flex and feel on water or rails.
HULL
Deep Symmetrical Channels – Help with acceleration thru a turn and push the rider into the wake.
RAILS/EDGES
Krypto Cable – Different fibers are brewed up and then woven together to make a stronger compound. The Krypto Cable surrounds the profile of the board and is fused together with the core. Combined with the monocoque laminated glass, this cable makes the sidewalls the strongest part of the board.
CORE
Mod Pour – An ultra stiff, lightweight, super saucy core - this demanding alternative foam is made from Ronix's exclusive blend of atoms. The highest strength to weight ratio Ronix has ever tested - setting the standard of the most refined recipe of foam out there.
LAMINATES
Monocoque – A wrapped glass from the bottom to the top so the flash line is no longer the weak point of the board - but is now the strongest. A more durable construction and a torsionally stiffer ride.
Magic Carpet – Every Year, Ronix sources new fiberglass materials trying to find that perfect weave that allows just enough resin to bleed thru and adhere to our magic carpet.
BASE
Sintered Base – The most durable non-stick base material Ronix has ever tested on rails, and has increased glide speed on the water. The exclusive base was formulated from a powder by heating the material in a sintering furnace below its melting point until the particles bond to one another. A higher purity compound that preserves its bond overtime. No obstacle is safe at cable parks with this jib friendly base material.
FINS
4 Alloy 1.0" Ramp Fins & 4 Fiberglass .8" Free Agent Fins
ADDITIONAL FEATURES
M6 Hardware – The Euros have it figured out. A higher thread count means more hold at a shallower depth. So now Ronix can go to thinner profiled boards with a shorter insert without sacrificing boot lock down. The result is boards with more feel and contact on the water.
• Ability Level:Intermediate-Advanced
• Riding Style:Wake
• Rocker Type:Camber
• Core Material:Foam
• Base Type:Standard Base
• Wakeboard Mount Pattern:M6
• Fins:4
Athletes:Erik Ruck
€ 499.00
Versand möglich 10€
B: Moody 346 in TOP-Zustand sea-commander Werbeforum 1 08.08.2011 16:42
Optima Blue Top, Optima Red Top, Optima Yellow Top alexmosel Werbeforum 3 28.10.2010 11:08
Helwig Triton Top Zustand vogtländer Werbeforum 6 18.02.2009 20:37
Alle Zeitangaben in WEZ +1. Es ist jetzt 05:05 Uhr.
