Nächste Seite - Ergebnis 26 bis 50 von 71
Alt 06.02.2013, 16:45
Benutzerbild von chris1003
2.572 Danke in 1.248 Beiträgen
Standard Badeplattform für Bayliner 245 Bestellung.
Hallo Freunde,
Hat jemand Interesse auch eine badeplattform für seine 245 iger zu bestellen.
Ich bestelle gerade eine für mich und kann dann Anfragen ob es günstiger kommt wenn wir mehrere oder 2 Stück kaufen. Käme eventuell günstiger für alle beteiligten wenn nicht nur eine bestellt wird.
Hier der link :
http://swimplatforms.contentpros.net...0/Default.aspx
Lg
Alt 06.02.2013, 16:48
Zur Info:
Hi Christoph,
Thank you for your time and interest in our Swim Platforms. Our Bayliner 245 SB Cruiser / 2455
Ciera platform was designed specifically for this model boat only. We have attached pictures of
our Bayliner 245 SB Cruiser / 2455 Ciera extended platform. We hope you’ll agree that this
complements the boat and makes a great addition. Just the safety factor alone makes an
extended platform a “must have” on your list.
Standard Features:
Our Bayliner 245 SB Cruiser / 2455 Ciera platform measures 90” x 35” of usable surface. The
platform is constructed of fiberglass with a gel coat finish similar to your boat’s construction. For
safety, the top surface has a diamond pattern non-skid in the gel coat. A heavy rubber molding
trims the bottom edge for an attractive look, as well as helping to ease those boating “bumps”. The
platform is tapered inward at the aft corners to allow for easy maneuvering around docking areas,
pylons and other boats.
This platform comes with an under mount telescoping triple step stainless steel ladder. The simple
one handed operation makes the ladder a breeze to use and stow. Our under mount ladder allows
the top surface to be clean and free of obstacles, complementing the boat’s clean design. The
steps are extra wide, measuring 2 ¼”. In addition, the bottom step is 39” from the top of the
platform making boarding the platform an ease. You’ll be spoiled by this “two tube” wide, three
step design (see attached pictures). Your old ladder is removed.
We install a large oval port in the platform allowing air and water pressure to transfer through. The
oval port can also be used as a grab handle while one is using the long boarding ladder. This
eliminates the need for a grab handle which is a possible tripping hazard.
We supply four stainless steel down rod supports for the aft end of the platform to give it added
stability. The underside of the platform has an easy to clean gel coated surface.
You can fit three or four people on the platform; we say 600 pounds…very conservatively. This
addition makes boarding, BBQ’ing and all around boating nicer and much safer!
Weight:
The platform weight is approximately 110 pounds. Shipping weight is about 350 pounds, due to
the crate and packing materials.
You will need to be able to offload it from the truck when the platform arrives.
Installation:
We provide stainless steel mounting hardware and installation guidelines. Due to your boat’s
manufacturing differences, the side flanges may need final shaping adjustments during installation.
Two people can usually complete the installation in less than half a day. You’ll need to supply a
tube of caulking; we recommend using 3M 4200 “fast cure” if launching the next day. Seventy
percent of our platforms are owner installed while other customers may use a local dealer, marina,
boat yard or handy person.
Warranty:
We offer a one-year warranty for workmanship and materials.
Should you ever have a concern or problem, please let us know. As an exclusive Swim
Platform fabrication company since 2001, we are extremely proud of our track record.
Our staff’s tenure nets over 175 years (that’s not a typo) of experience in the marine
industry and they are ready to build your new Swim Platform.
Pricing:
Our Bayliner 245 SB Cruiser / 2455 Ciera Swim Platform package is US$1445.00.
This includes all stainless steel mounting hardware, ladder, oval port, rubber molding and
Estimated Shipping:
Wood shipping crate and packing material is US$95
Please reply to this quote if you are interested in an exact freight quote.
It takes 2-7 business days for us to receive shipping quotes from our freight companies.
Please Note: Customs broker fees might be included. Taxes will not be included,
you will need to contact your local authorities.
Payment Options:
Due to the unstable costs of raw materials, this platform package quote is good for 30 days. We
accept MasterCard, Visa and wire transfers. We charge your credit card when the
platform is shipping. Since no deposit is required, ordering is easy. We build quality fiberglass
Swim Platforms and offer “Factory-Direct Pricing”. You can be assured that you will be getting
the best craftsmanship and pricing available.
Lead Time:
Our current lead time is about 2 weeks.
From February through August our lead times can be as long as four to five weeks since we build
each Swim Platform per order.
In Summary:
This extended platform is a perfect addition as boating safety is always a concern. Everyone
from kids to guests to boat owners will appreciate this platform.
As you may have noticed on our web site’s “Makes and Models” page, we strive for great looks
and functionality.
Alt 06.02.2013, 20:06
37.878 Danke in 22.677 Beiträgen
Hi chris
ich hhab da mla angefragt für meine 2855 und mir war dies zu teuer.
die Plattform hätte 1800€ gekostet und der Versand nochmal das gleiche.
hab grad bei Bayliner worms angerufen.
die machen eine für 1700€ das ist mir dan lieber.
Alt 06.02.2013, 20:26
Hi chris
das Problem ist das Worms keine für die 245 machen kann ohne das Boot vor Ort zu haben....
Alt 06.02.2013, 20:37
für meine 2855 auch nicht aber bei mir sinds nur 40 km
Alt 06.02.2013, 20:51
königsfamilie4 königsfamilie4 ist offline
356 Danke in 200 Beiträgen
Hy
Wenn in Worms was nachzufragen oder zu tun ist...
kann ich machen.....
Lg markus
Alt 06.02.2013, 20:54
ich hab mein Angebot schon und werd wohl vor dem Sommer vergrößern.
Alt 06.02.2013, 21:01
Zitat von königsfamilie4 Beitrag anzeigen
Hy
Lg markus
ja bitte frag mal nach, ich würde so wie im Link eine Plattform brauchen, eventuell kann er ja schon ohne Boot vor Ort was machen..
Alt 07.02.2013, 05:36
Ich werde heute Mittag mal nach Worms
Lg markus
Alt 07.02.2013, 06:16
Lg markus
dann frag ihn mal ob er für die 28er Bilder hat damit ich mir eine Vorstellung machen kann wies aussehen wird.
Sag ihm der der diese Woche angerufen hat aus Germersheim.
Alt 07.02.2013, 06:37
Okidokidoki
Wird erledigt
Alt 07.02.2013, 08:39
Benutzerbild von jogibaer1509
jogibaer1509 jogibaer1509 ist offline
Boot: Beneteau GT
962 Danke in 648 Beiträgen
und wenn Du schon mal nach Worm fährst wäre es super, wenn Du auch mal nach einer für meine 30er fragen würdest.
Danke
Viele Grüße von Jürgen
Alt 07.02.2013, 14:14
hallo
Chris... Er bekommt die Tage eine dann baut er dafür ne Plattform und Du kannst eine bekommen und mußt nicht mit Deinem Böötchen.
Volker... Wir haben tel. er kontaktiert Dich.
Jogibaer... Habe Deine Nachricht zu Spät gesehn aber ich bin fast jeden Tag in Worms und dann frage ich dort nach.
Oder rufe mal an.
P.s. Den Laden kenne ich noch aus Mopedzeiten als er Motorräder gebastelt hat.
Lg Markus
Alt 08.02.2013, 13:55
Danke
Die gefällt dir nicht?
http://swimplatforms.contentpros.net...6/Default.aspx
Alt 08.02.2013, 17:47
Wassersportler Wassersportler ist gerade online
Boot: Sea Ray 210 Overnighter
Hallo Freunde,
Hier der link :
Lg
kennst du den auch schon.
Alt 08.02.2013, 17:50
ja da hat in meinem alten Club einer für seine Marex ne Plattform machen lassen.
Inkl Anfahrt und Montage hat diese am ende ca. 8000€ gekostet.
ich hab in Worms angefregt was eine für ne Marex kosten würde und er kam 2300 zzgl. Teakauflage von 900€/m²
was am ende wesentlich billiger ist.
Alt 08.02.2013, 20:36
Habe heute mit der Firma Worms telefoniert, sehr netter Mann.
Er muss erst überlegen ob er meine Plattform wie ich sie wünsche machen wird, er muß sich erst das an einer 245iger ansehen, ich will nämlich keine Stufe von meiner derzeitigen Plattform zur neuen, er will sie aber mit Stufe machen....
Alt 09.02.2013, 14:49
Boot: Beneteau GT
Ich hatte mir die auch mal angeschaut, aber der Transport ist doch eine Nummer, die, die ich von Bayliner Worms finde ich recht gut gemacht und wenn dann mal etwas nicht paßt ist es einfacher in Worms zu schimpfen als in den USA.
Alt 10.02.2013, 17:08
Da gebe ich dir Recht, ich. Würde sie auch bei WORMS machen lassen wenn er diese bei meiner ohne. Stufe macht. Bei der 30 iger macht er diese ja sowieso ohne Stufe. Kannst mir einmal Fotos von deiner Plattf. Machen und mir per Mail senden. Danke wäre nett, oder stelle sie hier rein.
Danke
Chris
Alt 16.02.2013, 21:13
Hallo Chris
ich hab nun Antwort aus Worms un Beispielbilder bekommen und wollte sie auch nicht vorenthalten.
Hofe es ist kein Copyright drauf.
So würde es bei meiner 2855 aussehen.
Name:	2855 badeplattform-1.jpg
Hits:	899
Größe:	6,8 KB
Ich habe mich mittleweile fest entschlossen es in Worms machen zu lassen.
Nur der Temin ist noch die Frage.
Alt 18.02.2013, 06:12
Iderp Iderp ist offline
Boot: Sea Ray 210 Arcangeli Beelitz Carola
706 Danke in 338 Beiträgen
ich hab es endlich geschaft meine Badeplattform zu fotografieren.
Ich hab sie in Worms machen lassen und bin sehr zufrieden.Der Farbton wird speziell angemischt und passt perfekt.
Hits:	177
Größe:	57,9 KB
ID:	427657   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	194
Größe:	51,1 KB
ID:	427658   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	168
Größe:	71,5 KB
Grüße vom Neckar
Predi
Alt 18.02.2013, 07:37
Benutzerbild von polierpapst
polierpapst polierpapst ist offline
Boot: Bayliner 245
464 Danke in 270 Beiträgen
Da die Plattform ja etwas tiefer sitzt, würde mich interessieren, ob sie bei Gleitfahrt "im Wasser hängt" und dadurch eher stört.
Ralf
LEBEN UND LEBEN LASSEN
Alt 18.02.2013, 08:43
Hallo,Ralf
die Plattform ist ungefähr 20cm über dem Wasser.
Beim Gleiten kommt das Heck sowieso aus dem Wasser.
Meins ist das dritte vom links.
Hits:	181
Größe:	160,8 KB
Grüße vom Neckar
Predi
Alt 18.02.2013, 11:33
Benutzerbild von Tom-Cat
Tom-Cat Tom-Cat ist offline
Boot: Princess 46 Riviera
265 Danke in 146 Beiträgen
Hallo Volker,
ich habe auch eine 2855 Bj. 1995 und würde mich bei Deiner Bestellung mit anhängen.
Möchtest Du mal fragen ob beim Preis noch was geht wenn wir zwei Stück nehmen?!
LG Tom
Alt 18.02.2013, 11:50
kann ich machen.
Ich bin bis jetzt soweit, dass ich heut mittag im Winterlager messe ob Platz genug ist zum Montieren und danach den Auftrag erteile.
Dann kann die Saison kommen.
willst du sie dann selbst montieren ?
meien wird ja von Hr. Class montiert.
Alle Zeitangaben in WEZ +1. Es ist jetzt 20:28 Uhr.
