Für alle die das Vendee Globe verfolgen hier eine Gratisapp (ich glaub es gibt auch eine Androidversion):
https://itunes.apple.com/at/app/vend...573615421?mt=8
Servus felix
Danke. Noch 3 Tage.....
"Der Tourist zerstört, was er sucht, indem er es findet." - Hans Magnus Enzensberger. |
Marc Guillemot, SAFRAN, ist draußen. Nach nur wenigen Seemeilen eine Berührung mit irgendwas und in der Folge ein Kielbruch ist schon brutal.
Während der Youngster Francois Gabart (MACIF) noch an der Spitze zu finden ist, gefolgt von Vincent Riou (PRB) und ArmelLe Cléac'h (Banque Populaire) - wenn es so etwas wie Favoriten gibt in dieser Vendée Globe, dann diese beiden - kollidierte Groupe Bel mit einem Trawler.
According to Kito de Pavant and his team, the port outrigger, the bowsprit, the deck and the upper side of his hull were damaged in the collision. De Pavant has managed to secure his rig is reported to be safe and uninjured. According to the skipper from Port-Camargue in the Mediterranean, the trawler which collided with Groupe Bel boat did not have AIS (Automatic Identification System) activated. “Kito has a huge experience. He has secured his rig and is safe”, said Denis Horeau race director of the Vendée Globe during the daily radio interviews. “He should be able to sail safely to Cascais.” Groupe Bel is making around 9kts, sailing with a double reefed mainsail in a north westerly wind in 20knots with a swell of 2.5 meters.
Louis Burton hat auch umgedreht. Hat ebenfalls Nachts einen Fischkutter gestreift:
"In fact I was going through the front and had a couple of hours to go and had 30-35kts of wind. There was very poor visibility, rough seas and I had the radar and the AIS on. I was under the canopy to nap a bit and was making about 20kts. I turned my head bit and so a medium sized trawler slide along the hull. I grabbed a light to inspect the hull in a panic to see if it was OK. I was relieved but then saw the damage to the shroud. I tacked on to starboard immediately and focused first on Lisbon looking to get to land as quickly as possible." |
Ach ja, ein Want ist beschädigt und er segelt wohl zurück zum Start zur Reparatur.
... das Rennen an der Spitze bleibt spannen, und so langsam aber sicher holt auch Bertrand de Broc, der Mann mit den vielen privat Sponsoren, auf. Bertrand der Broc musste neu starten, da sein Boot unmittelbar vor dem Start den Rumpf beschädigt hat.
Armel Le Cléac´h (Banque Populaire) liegt nun vorn, die MACIF
von François Gabart an zweiter Stelle, weiter hinten hat es Sam Davis erwischt. Wenn das so weiter geht werden nicht viele zurückkommen. Langsam frage ich mich, ob diese Open 60 noch die richtigen Schiffe sind um Einhand um die Welt zu segeln. Bislang ist glücklicherweise kein Personenschaden zu vermelden. At 1945hrs (French time), on Thursday, November 15th, Samantha Davies contacted the race office of the Vendée Globe to report that her boat had dismasted. Davies is not injured. She is safe inside the boat with all the watertight doors closed.…
"Der Tourist zerstört, was er sucht, indem er es findet." - Hans Magnus Enzensberger. Geändert von Ricardo (16.11.2012 um 08:10 Uhr) |
Die Vendée Globe ist spannend wie selten, und unheimlich schnell. Ein neues Rekord etmal von Jean Pierre Dick (Virbac Paprec 3): 502,53 miles at 09h00 UTC (average speed of 20.9 knots)
First ship is home
Der Fan Club von Alessandro Di Benedetto
http://www.youtube.com/watch?v=pxNZvtAmMno
Passend zum Thema: gibt einen Film mit einem Open 60
Turning tide Schöne Bilder...
Viele Grüße vom Bodensee Tom FSD e.V.: www.fsd-info.de Bei Interesse gerne Infos per PN!
zu dem Film hätte ich mal eine Frage: In der Scene wo das Boot Kiel oben schwimmt sieht man einen Propeller am Schifsboden ist das eine Logge oder haben diese Boote tatsächlich einen Hilfsmotor? MFG S PS ich hab keine Ahnung vom Segeln geschweige denn von Regatten, aber den Film find ich gelungen vor allem weil nicht in iregndeinem "Wellenbad" gedreht.... |
Ja, ein Motor ist vorgeschrieben. Die Regeln gibts bei der IMOCA nachzulesen.
IMOCA Class rules 2015 C.4.1 ENGINE (a) Performances to be achieved When motorised, the boat must achieve the following performance and these measurements must be able to be checked at a race finish: - Traction value of 280 daN at a fixed boat (boat tied to the dock, traction measured with a dynamometer) for 15’. - Generate a 5 knots speed at sea with a demonstrated range of 5 hours. (b) Engine type The engines can be either internal combustion or electric. (c) Special measures (i) The elements that form an integral part of the engine cannot be removed or modified. However, they may be replaced on a like-for-like basis. (ii) It is possible to add to the ‘standard’ diesel engine, for example an extra alternator or a larger or additional alternator, and ‘standard’ diesel engine accessories (d) Internal combustion engines (i) For internal combustion engines, solely standard series diesel engines (namely self-igniting via fuel compression) with a minimum ‘manufacturing standard’ power of 37 HP are authorised. (ii) The engine shall be securely protected. (iii) The engine shall be permanently installed in the boat and cannot be moved. (iv) The exhaust, fuel supply systems and fuel tanks shall be permanently installed. (v) The engine shall have adequate protection from the effects of heavy weather. (vi) When an electric starter is the only method for starting the engine, a battery or separate electric source, the primary purpose of which is to start the engine, shall be on-board. (vii) Each fuel tank shall be provided with a shutoff valve. (viii) Flexible tanks are not permitted as fuel tanks. (ix) All the required fuel (with the exception of 20 litres, see section C.1.3) shall be stored in fixed tanks. The transfer of fuel between tanks is strictly forbidden. (e) Electric engine Electric engines are allowed. They can be prototypes. (i) The engine shall be securely protected. (ii) The engine shall be permanently installed in the boat and cannot be moved (iii) The batteries used for electricity supply of the engine shall be attached to the boat and cannot be moved. (iv) The engine shall have adequate protection from the effects of heavy weather. IMOCA Class Rules 2015 18  (f) Propeller It shall be located below the waterline, as close as possible to the boat’s centreline, and shall be neither retractable nor foldaway, nor be located on a movable appendage. It shall be permanently positioned in the water flow running under the hull with zero heeling angle. (g) The engine controls (gears + engine speed) shall be within reach of the helming station on deck.
"Der Tourist zerstört, was er sucht, indem er es findet." - Hans Magnus Enzensberger. Geändert von Ricardo (08.03.2015 um 20:56 Uhr) |
The new Safran has been launched in Lorient
Thursday 05 March 2015, 20:42 After a year in the yard, the first new generation IMOCA was launched today (Thursday 5th March) in Lorient. An emotionally charged moment full of excitement for Morgan Lagravière, the 27-year old skipper, who will sail the new Safran in the 2016-2017 Vendée Globe.
Danke!
Was machen die damit? Ein und auslaufen ist doch eigentlich nicht vorgesehen und mit einer Reichweite von 5 Stunden kommt man weder an Land noch durch einen Sturm .... MFG S |
Aber natürlich haben die nen Motor. Batterien laden (noch keine Brennstoffzellen erlaubt so ich weis), und Mob, die Boote sind unter Segeln nicht so fix zu wenden. Hans |
Zweck ist wohl Rettung im Notfall, die Rettung von einem Havarierten anderen Teilnehmer gabs schon, und da ist ein Motor durchaus praktisch.
Die Hydralik wird oft auch mit dem Motor betrieben. Haben ja alle nen Schwenkkiel, sonst wären die nicht so schnell.
Ist ja gerade vor ein paar Wochen der Higo Boss passiert, beiim Barcelona Worldrace. Mastbruch in der Höhe Brasilines, konnten dann mit Motor in 3T agen an Land fahren.
Gruß Christoph Rest in Peace!- John Fisher- Volvo Ocean Racer 3/2018 #foreverfish https://ineuropaunterwegs.travel.blog/ |
| Themen-Optionen | |
