Vorherige Seite - Ergebnis 576 bis 600 von 903Nächste Seite - Ergebnis 626 bis 650 von 903
Alt 16.09.2009, 16:32
Benutzerbild von divefreak
zumindest is 90PS glaubwürdiger
2x90-5
Oder 2x90 +10
schlimmstenfalls 2x90-45
MFG René
Alt 16.09.2009, 16:35
Benutzerbild von Picton16ft
Zitat von bigboy Beitrag anzeigen
If I were you I would close the two top water inlet holes of. And make 1 big hole of the lower two holes.
I added a picture of my gearcase.
As for the PSI gauge I believe you will have to put a fitting in the engine. So drill and tap
Good idea to close the upper vents
A fitting is already available and an appropriate tube to the dashboard is also there. The only thing what is missing is your gauge Hurry up
1000in1day2014 - Baltic Tour
Alt 16.09.2009, 16:39
bigboy bigboy ist offline
110 Danke in 60 Beiträgen
The youngest loopers had this modification to the lower units! So if the engineers of johnrude did this modification it should be good (at least that's what i hope).
Alt 16.09.2009, 16:44
omas gurkenfass omas gurkenfass ist offline
Boot: p16/xr2
2.651 Danke in 1.299 Beiträgen
omas gurkenfass eine Nachricht über ICQ schicken
... are you really sure that there are such people ?
Alt 16.09.2009, 16:47
definitly not.....
I´ve got the prove on my place....
an old 9.9hp OMC Outbord...
what a clusterfuck, the best proof they took anything they could find and luckly created something that looked like an outboard
MFG René
Alt 16.09.2009, 16:53
ich weiß nicht was ihr alle habt, reicht euch der beweis nicht daß Altmetall auch ganz schön fix rennen kann
Wie gesagt Mercury kocht auch bloß mit Wasser
Alt 16.09.2009, 17:01
I cant speak about the engine block itself. But the other parts like mid and lower are better engineered than Merc IMO. I prefer to wrench on the mid and lower of the rude above the merc anyday.
And I have both Merc & Rude so I'm not biased.
  #608
Alt 16.09.2009, 19:11
Picton14ft Picton14ft ist offline
5.495 Danke in 1.377 Beiträgen
bigboy wird zum littleboy wenn wir an seinem merc vorbei fahren.
Alt 16.09.2009, 19:57
Boot: p16/xr2
... jo, ich weiss doch, mit 3l hubraum genauso fix wie der schwarze mit 2l
... to fit a 2 or 4hole cle box sounds a lot easier
Alt 16.09.2009, 21:05
Dafür ist deine Zicke 4 Füße kürzer und der Johnny macht 1 1/2k Umins weniger
Hubraum ist durch nichts zu ersetzen,... ausser durch noch mehr Hubraum (aber daran arbeitet Hagen ja )
Sorry, was?
4hole?
cle?
Alt 16.09.2009, 21:17
Boot: p16/xr2
... ich bin gespannt
Sorry, was?
4hole?
cle?
... original merc racing box mit nosecone und low water pickup mit 2 oder 4 einlasslöchern fürs kühlwasser, keine ahnung obs sowas von omc gibt/gab
Hits:	357
Größe:	61,3 KB
Alt 16.09.2009, 21:21
und ich erst
mal sehen wer zuerst die 120 aufm Tacho hat
Jo das gibts, keine Ahnung ob serienmäßig oder gebastelt. Aber so eine Box hatte der Motor dessen Kolben sich vaporisiert hat.
NC + LWP aber mit eine Übersetzung von 1:2 sowas blödes.
Alt 16.09.2009, 21:23
wie wärs mit ner Transplantation?
MFG René
Alt 16.09.2009, 21:27
800km Distanz zwischen Gear und Case
aber es ist ja auch noch nicht aller Tage abend, da wird sich sicher was organisieren lassen.
Alt 16.09.2009, 21:29
Boot: p16/xr2
... meinste nicht da ist schneller ein nosecone angeschweisst ?
Alt 16.09.2009, 21:33
Noch nie gemacht,... geschweißt mein ich, und schon gar nicht sowas.
Son paar Zahnräder zu Tasuchen stell ich mir einfacher vor (hab ich aber auch noch nie gemacht )
wir haben ja ein totes Getriebe da, das könnte man ja mal sezieren
Alt 16.09.2009, 21:55
Boot: p16/xr2
... nosecone anschweissen sind auf beiden seiten zwei schweisspunkte á ~1cm mit aludraht aus nem schutzgasgerät und der rest wird mit epoxy aufgefüllt, die alten löcher zugemacht, alles glattgezogen, geschliffen und lackiert
... dann bohrst du ein loch in den ansaugkanal vor die pumpe, schneidest gewinde rein, schraubst die fittings mit dem schlauch rein und gut
Alt 17.09.2009, 00:41
Haben sie verstehen was ich gesagt habe? Ich denke es nicht
Littleboy you wish. I would take your words back if I were you
Alt 17.09.2009, 00:43
Haha yes but more expensive. Anyway i have two cle's but they arent perfect either. I'm going to cone mine. Because they will blow out at around 90mph
Alt 17.09.2009, 09:50
klingt einfach
vllt was fürn Winter
Alt 18.09.2009, 13:48
Rascala17fm, mach mal deine PN-Box leer
  #622
Alt 21.09.2009, 10:27
Gestern Nachmittag war nicht zufällig jemand aufm Müggelsee?
Alt 21.09.2009, 11:52
Boot: p16/xr2
... sei froh drum, jan sievers
Alt 21.09.2009, 16:17
..., jan sievers
Alt 21.09.2009, 16:31
Benutzerbild von v-sprint
v-sprint v-sprint ist offline
Was hat man verpasst ?
Wurde ein neuer Rekord aufgestellt?
Gruss Stephan
Alle Zeitangaben in WEZ +1. Es ist jetzt 03:37 Uhr.
