Alt 26.02.2009, 21:03
Benutzerbild von White Flag
2.735 Danke in 796 Beiträgen
Standard Edelbrock 750cfm zu groß?
ich habe einen Mercruiser 5,7 Magnum.
Nun möchte ich evtl. auf Edelbrock umrüsten.
Kann ich für meinen Motor auch den 750cfm (EDE1410) nehmen, oder brauche ich den 600cfm (EDE 1409)?
Wenn beide gehen würden, wo liegen dann die Vor-, bzw. Nachteile? (Leistung? Drehzahlbereich? Verbrauch?)
Würde mich über zahlreiche Antworten freuen.
Gruss Dieter
Alt 26.02.2009, 21:17
Benutzerbild von Luckytilo
Luckytilo Luckytilo ist offline
549 Danke in 346 Beiträgen
Edelbrock sagt ja und ich übrigens auch....
750 cfm, square-flange, electric choke, marine ....#1410*
For use in marine applications, these Edelbrock carbs comply with U.S. Coast Guard safety standards. Cast surfaces are iridited with Teflon-coated shafts and pump arm for maximum protection. Other features include modified bowl venting, specially designed throttle shafts, accelerator pump seal, 3/8" inverted flare fuel inlet fitting, tube in airhorn for fuel pump vent, 5-1/8" flame arrestor flange, universal throttle lever and revised secondaries for improved transient performance. Note: These carbs have no vacuum ports and are not for auto use. Use our Carb Stud Kits #8008 or #8024 if needed, see page 41.Marine Carburetors For use in marine applications, these Edelbrock carbs comply with U.S. Coast Guard safety standards. Cast surfaces are iridited with Teflon-coated shafts and pump arm for maximum protection. Other features include modified bowl venting, specially designed throttle shafts, accelerator pump seal, 3/8" inverted flare fuel inlet fitting, tube in airhorn for fuel pump vent, 5-1/8" flame arrestor flange, universal throttle lever and revised secondaries for improved transient performance. Note: These carbs have no vacuum ports and are not for auto use. Use our Carb Stud Kits #8008 or #8024 if needed, see installation items.
Designed and calibrated for optimum marine performance in small-block and big-block V8 engines with Performer 2, RPM, RPM Air-Gap and Torker II manifolds and with Performer manifolds on large cubic-inch engines. Comes with: Metering Jets � Primary .113, Secondary .107; Metering Rods � .071 x .047; Step-Up Spring � orange (5" Hg).
Details
SKU EDE1410
Weight 9.00 lbs
VH SKU EDE 1410
Vendor SKU 1410
Price: $329.99
Alt 26.02.2009, 21:19
ivea ivea ist offline
2.111 Danke in 1.074 Beiträgen
Wenn Dein originaler Vergaser am Magnum noch i.O. ist, wird Dir der 1409 nichts bringen und ich wage zu behaupten, dass der 750er alleine angewendet Dich nur arm säuft, ohne dass Du von Mehrleistung sprechen kannst.
ivea
Alt 26.02.2009, 21:23
Benutzerbild von Cyrus
Cyrus Cyrus ist offline
42.937 Danke in 15.624 Beiträgen
Tilo,
bei welcher Drehzahl ist der 750 cfm Gaser für einen Standart SB gut?
Was willst Du für den 750er haben?
Mit sportlichen Grüßen
ᴒɦᴚᴝϩ
Siehe auch www.kegel.de
Kontaktdaten und Impressum
Alt 26.02.2009, 21:26
ivea
Genau da liegt der Hund begraben. Ich habe schon seit längerer Zeit Probleme mit meinem Vergaser.
Also würde man mir eher zu einem 600er raten?
Gruss Dieter
Alt 26.02.2009, 21:27
600 oder 650 cfm.
ᴒɦᴚᴝϩ
Alt 26.02.2009, 21:30
Deine 1. Frage kann ich leider nicht beantworten.... isch nix wissen.
Preis 150,- Kröten
Tilo,
Alt 26.02.2009, 21:31
600 oder 650 cfm.
Und wo liegen zwischen den beiden die Vor-, oder Nachteile?
Gruss Dieter
Alt 26.02.2009, 21:33
Momentan habe ich einen Weber drauf.
Folgende Nummern habe ich auf dem Vergaser gefunden:
8867
1109
2707
Kann mit den Nummern jemand etwas anfangen und mir sagen, mit welchem Ede der vergleichbar ist?
Gruss Dieter
Alt 26.02.2009, 21:37
Tilo.
guckst Du:
http://www.csgnetwork.com/cfmcalc.html
ᴒɦᴚᴝϩ
Alt 26.02.2009, 21:42
Er braucht also nen 850er
Alt 26.02.2009, 21:44
Hier ist noch ne nette Tabelle:
http://www.buicks.net/shop/reference/carb_cfm.htm
ᴒɦᴚᴝϩ
Ich habe den 1409 mit der "normalen Performer" Spinne am 5,7 gewählt. (Am 1409 steht im übrigen das W von Weber drauf) Im orignal Setup läuft er sofort gut. Wenn Du rumspielen willst nimm das Düsen-Nadel-Feder kit dirket mit (so umme 85$ wars denk ich) Dann kannst Du Ihn auf Dein Boot/Motor abstimmen) Ich denke, dass bei Deinem Magnum es bereits eine "Performer" ähnliche Spinne ist.
ivea
Alt 26.02.2009, 21:53
ivea
Da wären wir beim nächsten Problem.
Ich habe noch eine Edelbrock Spinne liegen. Dort steht aber keine weitere Bezeichnung drauf, außer "Edelbrock Performer".
Da gibt es doch aber auch sicher Unterschiede, oder?
Habe mal irgendwo was gelesen von "Je höher der Vergaserflansch, desto......." Was hat es denn damit auf sich?
Wenn der 750er die Bezeichnung EDE1410 hat und der 600er EDE 1409, welche bezeichnung hat dann der 650er?
So langsam bin ich vollkommen verwirrt...
Gruss Dieter
Alt 26.02.2009, 21:57
Benutzerbild von Jot.v8.A.
Jot.v8.A. Jot.v8.A. ist offline
4.115 Danke in 1.331 Beiträgen
gibt´s im marine bereich nicht
http://www.edelbrock.com/automotive_...c/marine.shtml
gruß jens
Habe mal irgendwo was gelesen von "Je höher der Vergaserflansch, desto.BESSER......" Was hat es denn damit auf sich?
Ein 650er ist 1409 . 600 ist dann 08
Alt 26.02.2009, 21:59
Edelbrock hat keinen 650er Marine so weit ich weiß. Der 650er ist entweder vom PKW oder einer von den anderen Hestellern.
Die Performer Spinne ist die gegenüber dem "Standard 5,7" leicht erhöhte. Die Performer RPM noch höher etc. Der Magnum könnte bereits eine performerähnliche drauf haben. Das weiß ich aber nicht sicher.
Das mögliche Drehzahlband liegt dann auch immer höher bei LEICHT zunehmender Leistung wo die Teile gut laufen. Im Boot brauchste aber von unten Raus einen sauberen Lauf. Würde daher die Performer nehmen, oder nur den Vergaser austauschen.
ivea
Alt 26.02.2009, 22:16
Benutzerbild von Onkel-Pit
2.015 Danke in 1.089 Beiträgen
nimm die Performer Brücke und vom User Sierra den 650er Holley. Die Kombination fahre ich selber in meiner. Der Motor läuft sauber im Standgas und dreht sehr gut durch bis auf 5500 U/min.
wenn Du den Holley nicht willst nehm ich ihn
Gruß Sven
Wenn der Vergaser aber zu groß ist vresäuft er unten rum und kommt dann nicht aus den Knieen.
Alt 26.02.2009, 22:18
JA und wer nimmt den EDE?
Alt 26.02.2009, 22:21
Ich meine den 650er von Sierra nicht deinen 750er.
Gruß Sven
Deswegen ja den 1409 = 600er
oder den oben erwähnten 650er
ivea
Dieter,
ich habe noch eine Weber vom 350 Mag mit mech. Choke.
ᴒɦᴚᴝϩ
Alt 26.02.2009, 23:19
Dieter,
Das hört sich doch gut an.
Ich bimmel morgen mal bei Dir durch.
Gruss Dieter
Alt 26.02.2009, 23:23
hatte das teil schon inne hand...
mir wollte er ihn nicht geben
also, mach dich auf ´was gefasst
gruß jens
duckundweg
Alle Zeitangaben in WEZ +1. Es ist jetzt 02:00 Uhr.
