Alt 05.04.2011, 09:49
Benutzerbild von Cyrus
Cyrus Cyrus ist offline
Standard Info: Ersatzteilversorgung und Motoren aus Japan
Diese Pressemitteilung flatterte eben rein
Mercury Marine meeting demand despite potential industry supply shortages
FOND DU LAC, WIS. (April 4, 2011) –
Mercury Marine today announced it is well
positioned to continue to meet market demand for most of its outboard and sterndrive
engines, despite potential supply shortages resulting from the devastating earthquake
and tsunami in Japan.
A global manufacturer, Mercury produces engines and parts primarily in North
America and Asia. Mercury facilities in North America and China are operating with no
current disruptions. The manufacturing of Mercury’s industry-leading MerCruiser
sterndrive packages, which are built in the U.S., has been virtually unaffected by supplier
issues.
Mercury will increase production rates of selected product families from April
through July to ensure continuity of supply.
Attwood, Land ‘N’ Sea and MotorGuide have not received any indication from
suppliers that near-term shortages are anticipated.
“We join the rest of the world in sending our thoughts and prayers to the people
of Japan as they continue the recovery process from these devastating events,” said
Mark Schwabero, president of Mercury Marine. “We were obviously very happy that
none of our people were injured, but this is a terrible human tragedy and a huge
economic event that impacts the entire world.”
Mercury’s small outboards (2.5 - 30 hp) are produced in Japan through a joint
venture with Tohatsu Corporation. The joint venture facilities in Japan were not damaged
by the March 11 earthquake, and are not located in the region directly affected by the
resulting tsunami. These facilities in Japan have continued to operate, using parts on
hand to build outboard engines. The joint venture has worked closely with its suppliers to
monitor and balance the availability of parts and to minimize disruptions.
Like other manufacturers, Mercury anticipates some supplier-related delays will
develop at the joint venture’s manufacturing operations in Japan. While Mercury
continues to take and fulfill orders as normal, it anticipates production disruption of
undetermined frequency in Japan in April for engines 30 hp and below, including a
shutdown that began April 4. Production of these engines by the joint venture will
resume April 11.
Many companies that provide parts to marine engine producers are located in
Japan. The earthquake and tsunami damaged facilities of several of those companies
and their suppliers, and some have reported problems manufacturing and shipping
products. Some have announced temporary shutdowns of manufacturing facilities.
“We continue to monitor the situation closely,” said Stephan Cloutier, vice
president of Mercury Marine procurement, “because many of our direct suppliers are
dependent on materials and goods from other companies, several of which have been
affected to varying degrees.”
Although manufacturing disruptions are not currently anticipated for most
Mercury engines, the company will allocate outboard engines of all sizes in order to
consistently meet future demand and to protect its customers by fairly and equitably
supplying boat builders and dealerships across all global sales regions.
About Brunswick
Headquartered in Lake Forest, Ill., Brunswick Corporation endeavors to instill "Genuine
Ingenuity"(TM) in all its leading consumer brands, including Mercury and Mariner
outboard engines; Mercury MerCruiser sterndrives and inboard engines; MotorGuide
trolling motors; Attwood marine parts and accessories; Land 'N' Sea, Kellogg Marine,
and Diversified Marine parts and accessories distributors; Arvor, Bayliner, Boston
Whaler, Cabo Yachts, Crestliner, Cypress Cay, Harris FloteBote, Hatteras, Lowe, Lund,
Meridian, Princecraft, Quicksilver, Rayglass, Sea Ray, Sealine, Suncruiser, Triton
Aluminum, Trophy, Uttern and Valiant boats; Life Fitness and Hammer Strength fitness
equipment; Brunswick bowling centers, equipment and consumer products; Brunswick
billiards tables and foosball tables. For more information, visit
Mit sportlichen Grüßen
ᴒɦᴚᴝϩ
Siehe auch www.kegel.de
Kontaktdaten und Impressum
Alt 05.04.2011, 11:29
teuchmc teuchmc ist offline
234 Danke in 153 Beiträgen
Moinsen!Da mein "inglisch" ziemlich besch....n ist.Man kann auch sagen nicht vorhanden ist,wäre es nicht schlecht,wenn der Inhalt im Groben mal ins Deutsche übersetzt werden könnte.Danke!
Nen schönen Tag weiterhin.
Alt 05.04.2011, 11:32
Benutzerbild von Ruby
Ruby Ruby ist offline
17.129 Danke in 4.120 Beiträgen
so im Groben - nix geht mehr
Alt 05.04.2011, 11:49
Astrogator Astrogator ist offline
723 Danke in 304 Beiträgen
Das ist aber sehr grob....
Aussenborder von 2.5 - 30 PS werden Lieferschwierigkeiten haben. Sowohl die Motoren als auch die Ersatzteile.
Der Rest ist nicht oder marginal betroffen und sollte weiterhin funktionieren.
Gruss Marcel
Alt 05.04.2011, 12:01
JohnB JohnB ist offline
Boot: Hellwig Milos
7.874 Danke in 3.930 Beiträgen
Typischer Vertiebstext:
Zuerst jubelndes Eigenlob wie toll man ist, wenn man gewährleistet, daß
ie Sonnenscheindauer in Michigan erfreulicherweise von Vorkommnissen
in Japan nicht betroffen sein wird.
Dann erst gegen Ende kommt die eigentliche Information, daß es bei AB
bis 30 PS zu merklichen Problemen kommen kann, man aber vorallem gar
nix genau weiß.
Beste Grüße
John
Alt 05.04.2011, 12:26
So wie ich hörte hat Tohatsu die Hälfte der Belegschaft zum helfen in das Krisengebiet geschickt und die andere Hälfte produziert nur noch Pumpen.
ᴒɦᴚᴝϩ
Alt 08.04.2011, 08:15
Benutzerbild von ABI400
ABI400 ABI400 ist offline
Rufzeichen oder MMSI: Lotti
Hilfe ist in Japan nach meiner Meinung sehr wichtig.
Auch ich habe bei einem Netzwerk gepostet ,das ich
Hilfe anbiete.
Tohatsu hat wohl die Hälfte der Belegschaft zum helfen
in das Krisengebiet geschickt - das finde ich gut -da müßte
man gleich einen Tohatsu kaufen,aber den 6 PS Motor mit Kurzschaft
auch der von Mercury F6M ist nicht zu bekommen in Deutschland.
Ford400.nPage.de
Mail: Ford400@web.de
Alt 08.04.2011, 08:33
Das liegt daran, das die neue Modellreihe vor der Tür steht.
ᴒɦᴚᴝϩ
Alt 08.04.2011, 09:31
Neue 4 - 5 - 6 Tohatsu/Mercury Motoren sollen frühestens April lieferbar sein.
Die neue Schaltung gefällt mir sehr gut.
Siehe PDF
Angehängte Dateien
Dateityp: pdf 4-5-6 PS 4-Takter redesign.pdf (1,18 MB, 215x aufgerufen)
ᴒɦᴚᴝϩ
Alle Zeitangaben in WEZ +1. Es ist jetzt 18:47 Uhr.
